View Templates
5 ANTWORTEN 5
Nachricht 1 von 6
MS_jkimc65
591 Aufrufe, 5 Antworten
View Templates
To those who are in the architectural industry, I would like to know on average for your projects how many view templates you may have within your office standards?
j. kim candelario
method-studio, inc.
5 ANTWORTEN 5
Nachricht 2 von 6
EATREVITPOOPCAD
als Antwort auf: MS_jkimc65
I imagine you will get a wide range of responses...
We recently transitioned to Revit, so my guess is this will change quite a bit, but here are our view templates:
  1. AREA PLAN
  2. SITE PLAN
  3. ELECTRICAL PLAN
  4. ELECTRICAL ROOF PLAN
  5. EXITING PLAN
  6. FLOOR PLAN
  7. ROOF PLAN
  8. DEMOLITION PLAN
  9. BUILDING SECTION HATCHED
  10. BUILDING SECTION UNHATCHED
  11. ELEVATION
  12. WALL SECTION HATCHED
  13. WALL SECTION UNHATCHED
Now I got this list by opening a random project we have, so not every job has this. Some can have more, maybe there is a need for a view template that is similar to an existing view template but it's just slightly different...
The definition of insanity is doing the same thing over and over again and expecting different results
Nachricht 3 von 6
Code Compliance Site Plan
Code Compliance Plan - Egress Zone
Code Compliance Plan - Exiting
Code Compliance Plan - Plumbing
Site Plan - Key
Site Plan - Partial
Demolition Plan
Floor Plan - Key
Floor Plan - Quadrant
Floor Plan - Enlarged
Floor Plan - Background for Consultants
Finish Plan
Wayfinding Plan
Furniture/Equipment Plan
Reflected Ceiling Plan - Key
Reflected Ceiling Plan - Quadrant
Reflected Ceiling Plan - Enlarged
Reflected Ceiling Plan - Background for Consultants
Exterior Elevation
Building Section
Wall Section
Interior Elevation
Exterior Detail - Plan
Exterior Detail - Section
Exterior Detail - Drafting
Interior Detail - Plan
Interior Detail - Section
Interior Detail - Drafting
A few 3D view templates
A few Schedule templates
A template to reset ALL overrides
Nachricht 4 von 6
EATREVITPOOPCAD
A template to reset all overrides: does that reset line weight tool overrides also?
Nachricht 5 von 6
als Antwort auf: EATREVITPOOPCAD
You mean Linework tool?  No.  This only resets what overridden by other view templates, not by elements or by linework tool.
Nachricht 6 von 6
constantin.stroescu
for medium projects we use :
  • for Floor Plans, Elevation and 3d Views (if we have to work on existing building then also split by Project Phases):
    • Work (Default View) - (useful to go back to no override settings while None option does not restore the default)
    • Hand Sketch View - for draft presentation in Conceptual Design phase
    • Presentation View - for Precontractual phase
    • Liniar Technical View - for Contractual Phases
  • Fire Protection  - Floor Plans with Filters - color codes
  • Area Schemes  - Floor Plans with Color Schemes for Gross Areas and Net Areas at different scales . Some are use as Tumbnails placed  above the title block.
  • Callout Views - I use them for Curtain Wall, Doors and Windows instead of Legends
we complete these with other View Templates and incorporate them into the Project Template if necessary...
Constantin Stroescu
