view template mismatch floor plan
5 ANTWORTEN 5
Nachricht 1 von 6
701 Aufrufe, 5 Antworten
I have created several floor plans and then assigned view templates with appropriate names  in the type properties. (Plumbing floor plan - plumbing view template,  Hydronics floor plan - hydronics view template).
However, when I go exactly to a floor plan, view templates do not match the floor plan (as shown below in red).
How can I fix it, so the view template automatically changes according to the floor plan?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
"View Template applied to NEW views", not existing.
Nachricht 3 von 6
als Antwort auf: barthbradley
Where can I find that?
Nachricht 4 von 6
I'm saying: create a brand new Floor Plan and it will use that template. It doesn't work retroactively.
Nachricht 5 von 6
peteregan
Egan BIM Resources has an app for that. This is a free app.
It is called Project Startup and is available from the Egan BIM Resources web site or the Apps Exchange.
From the Help file:
Automatically Swap View Template When View Type Is Changed
If a View Type has a “View Templates applied to new views” setting, and “New views are dependent on template” is checked, the app will automatically apply the correct view template whenever a view’s View Type is changed.
Nachricht 6 von 6
italonge
als Antwort auf: peteregan
Same problem here... Would be very nice to change the Flor Type and automatically change de View Template...
