View Template for Window Types (Curtain Wall) Elevation
2 ANTWORTEN 2
Nachricht 1 von 3
hliS658H
199 Aufrufe, 2 Antworten
I am creating curtain wall type elevation using building elevations,  using filled region to hide anything else except curtain wall, but is there a way to set the view template to only show curtain wall? I tried to uncheck everything except curtain wall related , but everything disappeared. What else should I check in the model category?
2 ANTWORTEN 2
Nachricht 2 von 3
vitorbortoncello
als Antwort auf: hliS658H
You have to check the walls category, but every wall appears. You could just select the curtain wall and isolate element
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 3
Lachlan-JWP
You can also use a view filter to hide wall you do not want to see.
