View template doesn't affect levels below
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
832 Aufrufe, 8 Antworten
Hello everyone,
I'm trying to print my project using a view template. Apparently everything works fine except for the fact that the view template I am applying is not affecting the objects placed on the level below. For example if I set a certain line weight to furnitures, the process affects all the items in the level I'm in but not the items displayed below. I hope i explained myself.
Is it a problem of revit itself or am I making some mistake?
Thank you.
8 ANTWORTEN 8
Nachricht 2 von 9
MKJOR
als Antwort auf: Anonymous
Try adjusting (View Range) and/or (Clipping Plane) in the View Template.
Nachricht 3 von 9
Can you take us through exactly what you did and where you did it?  Maybe screenshots would help too.
Nachricht 4 von 9
als Antwort auf: barthbradley
Here are some screenshot: the lighter one shows the items as i want it and is taken at level 0; the darker one shows the items from the level above, but in both is applied the same view template.
I noticed that if I change the underlay property from None to the level below, this one turns as I want, except for the fact that all the floors at level 1 turn trasparent (but this is the purpose for the underlay property).
Nachricht 5 von 9
Sounds like you figured it out. That's exactly what it looks like to me too. An Underlay.  So you're good?
Nachricht 6 von 9
Actually what I want is to obtain the same result I have when the underlay property is on, but maintaining the floors opaque and not transparent. Hope I explained myself.
In the attached you see what I get when I turn on the underlay property, and actually I don't want to see throush the floor (in the screenshot is shown a mezzanine and the level below).
Nachricht 7 von 9
Let's take a look at your View Template. Actually, just post the RVT.
Nachricht 8 von 9
Dear @barthbradley , I got it. It was my mistake: I didn't change the below part in the view section accordingly to the underlay property. Thank you for your help, I appreciate.
Nachricht 9 von 9
MKJOR
So, is it solved from View Range options?
