View/sheet parameters not being erased
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
442 Aufrufe, 2 Antworten
I've been struggling for several days with some view and sheet parameters in my projet. The problem is the next one: I'm unable to erase them, I've already checked they don't exist in the projet browser organiser and the project parameters. Yet they exist in the view/sheet properties. I've just taken the projet from someone else who used to work in the office  before, so I'm not sure about the method they used. I think these parameters were added as shared parameters at some point, however I find no trace of them but the view/sheet properties when selecting one item. I attach you an image with the **** parameters in question  highlighted. For your information, I'm using revit 2016.
Since I don't really think I'm able to find it out by myself, I'm looking forward for your feedback and suggestions thanks!
2 ANTWORTEN 2
Nachricht 2 von 3
rudi.roux
als Antwort auf: Anonymous
Hi @Anonymous
Welcome to the community! Smiley (fröhlich)
Is it possible to share the project? You can copy it to an external location, delete and unlink everything and purge the file. Make sure the title block is still included and that the problem still functions in the same way. Then share it for further investigation.
If you already check all of the Browser Organization and Project Parameters, there might be something small which is being missed.
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Nachricht 3 von 3
RDAOU
@Anonymous Hi
Those appear/seem to be the shared parameters carried over from the sheet's Title Block and not the view.
Did you try to edit the family and check the parameters therein?
