View settings reverting for linked DWGs
2 ANTWORTEN 2
Nachricht 1 von 3
kcommins
239 Aufrufe, 2 Antworten
I am linking 2D CAD files to make coordination overlays. After linking I turn off most of the layers using visibility graphics  Imported Categories tab. I then select the linked instance and Override graphics by category (by element) to make the linework a different color for each discipline. The issue is that these settings are being lost after saving/reopening and the DWG reverts back to the imported settings . I have used this workflow for years, although it might be the first time doing it in Revit 2020. Any ideas? Maybe I'll just convert to 2021.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: kcommins
Doesn't seem to be the case with Revit 2022.
You, however, could create a view template to hold the Import Categories VGO and re-apply it to the view incase it is lost.
Nachricht 3 von 3
kcommins
als Antwort auf: ToanDN
Thanks. That isn't too bad of a work around. I'll see what happens when I go to 2021.
