View Sections
5 ANTWORTEN 5
Nachricht 1 von 6
jfjacques
371 Aufrufe, 5 Antworten
View Sections
I have two views, one of the em shows the section the other doesn't. They are the same view.
View range is the same,
VG is the same,
nothing shows up as hidden.
What's going on?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: jfjacques
Reveal Hidden Elements (Lightbulb). See anything?
Here's a good list to keep handy:
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Nachricht 3 von 6
zeulrick
Go to the section view and find Hide scales coarser than... and select the appropriation scale. This may be it.
Nachricht 4 von 6
ennujozlagam
you can try this go to the view that you can see you section line then create a view template in that view and name it as TEST for example or you can rename it as what you want, now go the view that you can't see the section line and apply the view template you just created if you manage to see the section line set the view template to none and see if helps. thanks
Nachricht 5 von 6
_Vijay
try to apply same view template in with views.
Nachricht 6 von 6
martijn_pater
als Antwort auf: _Vijay
Might be discipline related... could be a view filter...
