View reference isn't referencing
PDSF
Message 1 of 9
PDSF
Hi all. I'm baffled by an issue I'm having setting up a relatively new project (but not so new that it doesn't have some garbage in it). I imported two view reference families we have used without issue in the past. One is the typical bubble and one is a horizontal text reference. But when I click on either of them, they don't bring up the option to change the reference. They also look a bit different in the browser and in the properties pull-down. I have tried removing / purging / re-importing, no luck. What am I doing wrong? Attached are images of the good one and the bad one with the differences indicated. Any help would be gratefully appreciated. TIA.
Replies (8)
Message 2 of 9
Lachlan-JWP
Can you upload an example of a project where they aren't working? I have a couple of ideas but it would be easier to test them and let you know what I find.
Message 3 of 9
PDSF
I can't, the client wouldn't like it, but I can upload the families. Here they are. Let me know if they give you any clues. Thanks.
Message 4 of 9
Did you create a view reference type and assign this family to it?  They work fine here.
Message 5 of 9
Lachlan-JWP
No issues on my end. Have a look at the legend in the attached project. I loaded each family in and created a new type of view reference that used the relevant family.
The only thing I can think of is that you're not creating the types correctly. Other than that, if you can recreate the issue in a blank project and upload that, I'll have a look.
Message 6 of 9
PDSF
This will sound stupid, but I don't know what you mean by "create a new type of view reference". If I place a default view reference and check the type properties, this is what I see. There is no option to assign the family that I can see.
Message 7 of 9
PDSF
Update: It was my stupidity. I forgot I had purged those families out of the project again. It is working now. Thanks to both of you.
Message 8 of 9
Click View Reference button and you will be shown with a list of existing View Reference types. Pick anyone of them, edit type, duplicate, and assign a family type of the two families you shared.
Message 9 of 9
Lachlan-JWP
That is your problem then.
here is what I see:
