View Range Visual
View Range Visual
MargaretLogas
Observer Observer
View Range Visual
MargaretLogas
Observer
Observer
The View Range is a great tool but I often have problems knowing where to set the cut planes or where to start and end to see what I want to see, especially if what I want to see is not appearing. What would be great is if we could cut a section and see what the View Range is encompassing, then be able to adjust it live. For instance, it would be helpful if the specified View Range was highlighted in a section.
arq_42
There are some ideas in the ideas forum asking for this. (like that)
You could vote them.
Also, the pyRevit plugin has a tool that shows you your actual view range in a 3D view. It's not the same that you are looking for, but 🤷‍♂️
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
imankassab2015
If you want a portion to use view range you can use plan region and set the view in a certain area to be different from others ... check the attached photo
Accept or like my answer if it helps you
mari.shimode
Hi @MargaretLogas, did you find the information provided useful? If so, please use Accept Solution so that others may find this in the future. Thank you.
Mari Shimode
