in view range cutoplane,bottom,view depth in 500, why floor visible cutplane & bottom < 1000 mm floor visible
in view range cut plane & bottom 1500 floor not be visible, even though the cut plane & bottom should be at 100, the floor should not be visible, because the view depth is already above 500, above 0, floor level 0
I think this is not Visible !!
yes, if the cut plane & bottom are at 1500 the floor is not visible, but if it is below 1000, for example at 1000 cut plane & bottom, the view depth is 1> more, the floor should also not be visible, but it is visible, because view depth is the lowest limit of vision , and floor is at elv 0
