View range problem
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
mairh_tsek
469 Aufrufe, 4 Antworten
View range problem
Hello all,
I created a structural floor in level 0.00. I set the view range of the floor plan to 'level 0.00 with an offset 1.0'
I can not understand why the structural floor is still visible in the floor plan of level 0.00.
Thank you in advance!
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: mairh_tsek
Floors within 4' beyond the view range are still visible in that view.
Nachricht 3 von 5
Avaris.
Nachricht 4 von 5
It's within 4 ft. of the bottom clip plane.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
BTW @mairh_tsek: Where have you been? Long time no see.  Guess you're gotten pretty good. Don't need our help no more.
Nachricht 5 von 5
mairh_tsek
als Antwort auf: barthbradley
Oh I didn't know that..Thank you a lot!
@barthbradley hahah, I always need some help from specialists and thank you for that! if you check the structure forum you will understand where I was yesterday:p
