Hello, im new at revit and i have a little problem.
I have a concrete structure with metal beams above, I am trying to generate a floor plan where you can see the metal beams.
I try to generate the plane with the view range associated with level 4 and the metal beams are not visible, should not these be seen if the top view plane is above the metal beams? And I do not understand why if the lower plane is at -0.5 and the view depth is at -0.6, the lower slab is visible
Sorry about my english, thank you
thanks for the reply, It's probably a solution, but what I'm looking for is trying to understand why it does not work this way
