Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Welcome to Autodeskā€™s Revit Architecture Forums. Share your knowledge, ask questions, and explore popular Revit Architecture topics.
Showing results forĀ
Did you mean:Ā
View Range Problem
7 REPLIES 7
Message 1 of 8
7582 Views, 7 Replies
View Range Problem
All levels offset on zero and my reference level is on associated level .
If top , cut plane , bottom and depth level are all set to associated level  and depth level is also set to associated level and all offset are given zero mm ; this means I should not be able to see anything below associated level ;
  But I'm seeing everything below assoicated level .
   This is  my problem .
7 REPLIES 7
Message 2 of 8
Ilic.Andrej
Check if the underlay is set to "none". If not, set it to "none".
Andrej Ilić
phonetical: ƦndreÉŖ ilich
MSc Arch
Autodesk Expert Elite Alumni
Message 3 of 8
planner_matlabi
for invisible lower level must none underlay in Properties
select Level
in Properties
underlay
none
If it solves your problem, feel free to click Accept Solution.
Message 4 of 8
Corsten.Au
1. turn off wire frame
2. no underlay
3. if thats the CAD import then you know what to do....
4. have a floor for current level so that item below would not be visible...
( most probably its just an underlay which you need to set to none )
Corsten
Building Designer
Message 5 of 8
ennujozlagam
most probably set underlay to none or check if there is plan region hidden in that view activate the bulb icon. thanks
Message 6 of 8
Karol_Piroska
I would say the issue is with a linked file that has linked view with its own view range.
Message 7 of 8
in reply to: Ilic.Andrej
Thanks a lot sir.
Message 8 of 8
in reply to: Karol_Piroska
Thank you for your participation. I got the solution from a fellow revit user . I've accepted his solution and you can take a look .
