view range issue
2 ANTWORTEN 2
Nachricht 1 von 3
247 Aufrufe, 2 Antworten
view range issue
Refer to the following image,
View range set to default. But it shows level below even the bottom set to associated level. How to solve this issue. Any ideas?
It happened after sometime working in the same drawing.
Tags (1)
2 ANTWORTEN 2
Nachricht 2 von 3
Sahay_R
als Antwort auf: Anonymous
Look in your Properties palette. Make sure that Underlay has been turned off.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 3
...any resolution on this? Looks like you are picking up the lower level annotations as well. If so, this wouldn't be a related to Underlay.
