view range issue
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
roscopeco2000
490 Aufrufe, 6 Antworten
view range issue
i thought i understood view range but the grey line outside my wall construction below is my roof construction its non selectable, so i cant hide it either. I have tried playing around with the top plane and cut plane but it still displays how can i get rid of?
6 ANTWORTEN 6
Nachricht 2 von 7
Ilic.Andrej
als Antwort auf: roscopeco2000
Select the floor plan view and in properties palette, set underlay: none
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 7
roscopeco2000
als Antwort auf: Ilic.Andrej
ok in the floor plan properties how can you set underlay to none? there doesn't seem to be option to do
Nachricht 4 von 7
Your mouse cursor is already on it - First Floor box next to Range: base level. Now click.
Nachricht 5 von 7
Ilic.Andrej
Play with this options
Andrej Ilić
MSc Arch
Nachricht 6 von 7
roscopeco2000
als Antwort auf: ToanDN
LEGEND!!! THANKS
Nachricht 7 von 7
chrisplyler
If your problem was solved, please select one or more of the posts as Solutions to the thread.
