View range help
View range help
ritztran
Message 1 of 9
View range help
ritztran
I have this issue. The floor height is 10'-6", and I set the cut view @ 7'-6". In the attached image, the left cut line is at 7'-6", but i don't know why there is an another one on the right. I check all the work sets to see if there is a view region, but there is none of view region. Has anyone experienced something like this. Please tell what is going on. Thank you in advance.
Replies (8)
Message 2 of 9
It doesn't look like the View Range Box captures that area. If you enlarge the box, is it still there?
Message 3 of 9
Can you cut a section thru the stair?
Message 4 of 9
aRcHiTeCt.JM
... how many floors on that stair?
.... check the range of all settings
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 5 of 9
ritztran
That dashed line box is the group of the stair. I only placed a view region at the door opening.
Message 6 of 9
ritztran
Here is the section. The plan view is Level 6, and the typical height is 10'-6".
Message 7 of 9
ritztran
Sorry everyone. I know the reason now. It's because I set the top Level @ Roof Level. Even it appears right in 3D view, but in plan view is not. I have to change the top level to Level 6. Thank you everyone for spending time figure this out for me. I really appreciate it. Thanks a lot.Capture 2.JPG
Message 8 of 9
Sorry. Misread issue initially.
Just to clarify: is that a Plan View or and RCP View? It's not readily apparent to me.
Message 9 of 9
ritztran
It's a plan view. I was doing plan view in a stair tower, and I wanted to show the intermediate landing, so I had to cut it at 7'-6".
