View Range gray-outs
8 ANTWORTEN 8
Nachricht 1 von 9
rmaynard
790 Aufrufe, 8 Antworten
Cut plane & bottom are grayed out and can't be modified.  If I modify 'offset' numbers, I get an error message: "view depth plane is set below the top clip plane."...whatever that means.
8 ANTWORTEN 8
Nachricht 2 von 9
ralphdenhaan
als Antwort auf: rmaynard
Can you add a screenshot? It seems you try to change the view range of a reflected ceiling plan? Then the view range is oriented upwards and the bottom plane is not in use. The Cut Plane is locked to associated level. The View Depth must be atleast the same offset as the top (or higher).
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nachricht 3 von 9
Does the view have a view template?
Nachricht 4 von 9
kostask_oionei
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Nachricht 5 von 9
rmaynard
als Antwort auf: ralphdenhaan
Nachricht 6 von 9
juliar123
This is the default RCP for my level 1.
I think you're problem is the two different levels that your Top and View Depth are connected to.
Nachricht 7 von 9
ralphdenhaan
You have to lower the Top or make View Depth higher by changing the level or offset to a minus.
Now your View Depth is lower than the Top and that is not possible.
Also it's better to make the Reflected Ceiling Plan from level 1 as the associated level. Now you are using the Foundation level?
Nachricht 8 von 9
ralphdenhaan
als Antwort auf: juliar123
I don't think that makes the difference, it's because the View Depth for reflected ceiling plans must be at least the same height as the Top or higher. (print screen below works as long as the View Depth is higher than Top).
Nachricht 9 von 9
kostask_oionei
I think @ralphdenhaan has right.
That is that I try to describe me too with my screen shot above. View depth is the plane where we can see. It's impossible to be lower than the top.
Kostas Kouris
