I'm using Revit 2023.
I wonder if there is any idea how to show gradually fade elements in site view??
the closet element should be thicker than the farset element.
for example:
the higher roof lines should be thicker than the lower roof and the site itself should be fade.
thanks
I think that is only possible in elevations/sections.
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Edited.
I was referring to the depth cueing too but i have all my revits installations in spanish and i was no sure what the english words were.
It wasn't my intention to offend you, so sorry if you thank that. As I told you I have edited my first reply.
Have a nice day
You could get there by overlaying views on sheets.
... you could also employ this method (albeit, maybe a little more work):
