View Range for stairs and their railings' above cut lines?
3 ANTWORTEN 3
Nachricht 1 von 4
gnarkill283
836 Aufrufe, 3 Antworten
I want to see a stair's above cut lines but only to a certain extent. I know I can turn them off entirely but I need to show them up to a certain point for egress drawings. If there's no such thing, then how are architects supposed to show length of runs and railings for a stair that runs multiple floors if the above cut lines follows it through multiple floors and makes the plan unreadable? It would be nice if the top section of a plan's view range would cut the lines above.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: gnarkill283
Visibility and Graphics Overrides not working for you?
Nachricht 3 von 4
...what about Plan Regions around the Stairs?   That might be the ticket.
FWIW:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/screencast/Main/Details/fc6...
Nachricht 4 von 4
s.borello
Plan region will work for you.
