View range comparison - Unlimited depth but different visibility
12 ANTWORTEN 12
GELÖST
Nachricht 1 von 13
cbt990
653 Aufrufe, 12 Antworten
Here is a snip of a foundation plan - the green segment is a slightly deepened.
I have created a callout view. I can't get the deepened footing to display even though the view range is set to unlimited:
Revit is amazing
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: cbt990
Create the callout as Floor Plan, not Detail.
Nachricht 3 von 13
cbt990
als Antwort auf: ToanDN
Revit is amazing
Nachricht 4 von 13
Do you want to share the model for an immediate answer or keep playing the guessing game?
https://www.revitforum.org/node/459
Nachricht 5 von 13
Did you create that Linework in the View with the Linework Tool. Betcha did.
Nachricht 6 von 13
cbt990
als Antwort auf: barthbradley
rEAL BIM
Revit is amazing
Nachricht 7 von 13
cbt990
it works without issue in this dummy model.
Revit is amazing
Nachricht 8 von 13
 I don't see any issues with it. What am looking for?
Nachricht 9 von 13
Reveal Hidden Element?
Nachricht 10 von 13
cbt990
Deepened footing visible when intersected by cut plane:
Also see:
Depth of view extents somehow is reduced when I raise the cut plane:
Revit is amazing
Nachricht 11 von 13
Use a Plan Region then.
Sounds like you are describing Low Wall behavior (e.g. <4'-0").  Read more here:
About the View Range | Revit 2019 | Autodesk Knowledge Network
Nachricht 12 von 13
cbt990
Is there a way to hide the boundary of the plan region?
Revit is amazing
Nachricht 13 von 13
cbt990
It was another element causing the line. Thanks for the help.
Revit is amazing
