Hi all,
I am modelling a multridisciplinaty object.
I want to assign element to a particulary phase of erection (e.g. Piles phase 1, Columns phase 2...)
Each time I create a Section it will be assigned to a phase.
The section will be assigned e.g phase 3 but I want to see this section symbol in a floor plan phase 2.
Do I have all the time apply some king of phase philter or there could be way to do it easier?
You can create a section in your new phase and then reference the other section - see attached.
the phase mapping will do that
each view has its own phase and Phase filter.
if you need to see the sequence of construction duplicate the section views and assign different phase per section and apply the to a sheet in their native phase.
combining 3 views to create 1 section to coordinate the phases
