If I put 0.1 on scale on finishes i don't view the pattern.
If I put 0.2 yes but not in the side farther.
When I render I view however the pattern?
Thank's
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
You do not need to worry they are there you just don't see them because the scale of the Pattern is too small compared to the scale of the view...If a Model Pattern is too dense and crumbly with small line take quite some to regenerate. If you zoom in close and give it a few seconds you should see it.
Might also help a bit if you disable "Use Hardware Acceleration"; Otherwise, if nothing works you need to look for a better pattern
see screencast below for results
Not sure why it is not loading...I can see it on my end.
Somewhat right because the pattern will not really matter:) when you render you will see the render Appearance and which ever image and bump you set over there...below is not yours but what I mean that's the tab where you set your render appearance
