view filters
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
889 Aufrufe, 6 Antworten
view filters
It seems that I cannot apply view filters where structural framing members are part of group .
I was trying to filter out this framing group by its type name.
Is there any way to filter individual groups from view?
6 ANTWORTEN 6
Nachricht 2 von 7
rudi.roux
als Antwort auf: Anonymous
Hi @Anonymous
I hope you are well! Smiley (fröhlich)
It is possible by right-clicking on the elements/group in a view >> override graphics in a view >> By Element.
A quick sample can be seen below:
End Result:
I hope this helps! Smiley (fröhlich)
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Nachricht 3 von 7
als Antwort auf: rudi.roux
Thanks for the reply.
I do not want to override graphics
What I want is , Add view filter  via VG and take the visibility off by unchecking the checkbox of that structural framing model group by type name.
Nachricht 4 von 7
Type name of the group? I don't think group is one of the filterable
categories.
Nachricht 5 von 7
categories.
Nachricht 6 von 7
als Antwort auf: ToanDN
Thanks @ToanDN
someone in project team already created groups and its hard to filter out because we do not want to show services dropper structure in our framing plans.
I found Revit doesn't allow to filter group. There are few groups for now just made hide in view.
Nachricht 7 von 7
rudi.roux
Hi @Anonymous
As mentioned already, Groups can unfortunately not be filtered "by name" etc. What can be done, but which might take some time is to add a "Comment" to all structural framing instances (service droppers as you mentioned). Go to a default 3D view, make sure all groups and framing are visible. Select everything, then deselect the Grouped Elements (e.g. The ones which you would like to filter out/switch off under VG).
Then add a comment, e.g. - "Framing" to everything. Now, create a new Filter, e.g. - "Framing Groups" >> Define Rule >> Select the appropriate Categories >> Filter Rules by: Comments >> does not contain >> "Framing".
Then you'll be able to control the VG.
This would pretty much be a workaround for now.
Rudi Roux
LinkedIn
