testing view (section, callouts, interior elevation view, circle, etc) appearance with filters. With a primary intention of being able to hide specific view symbols with different templates. during my explorations, I'm using project shared parameters and type names to see how they work the best, so far I can't get the int elevations affected by filters with parameters & filters but can with family type name filters. Is there any way to control the int elev circle with parameters?
Also, when I try to affect both sections and int. elev lines through the filter, it completely works on the int elev but not on the section arrow lines, see pic.
here's a link to the project file ( https://drive.google.com/drive/folders/1R93zEhaCa_xyX2mwGvYpI54b2ZjThvSb ) also if that helps.. main view and visibility graphics override (filters). looking in the family for the section head and the int elev I can't determine what is causing the difference. Help would be greatly appreciated. Thanks in advance.
Create different view types and add filters to Elevations / Sections/ Callouts using Type Name Criteria. Example below is a filter for hiding any views with Coordination in the View Type name.
Also, utilize [Hide at Scale Coarser than... ] as well.
