View depth plane is set below the top clip
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
adri3362
1014 Aufrufe, 3 Antworten
Hello!
I have been working on ceiling plans. On one of them I can see that the stairs are visible through the ceiling. I thought that it is maybe because of the view range. However every time I try to change the View range I get an error which says: "View depth plane is set below the top clip plane". Also the funny thing is when I am changing back to the setting that were set before I get the same error. Do you have any ideas how to solve it ? or how to adjust the plan so I don't see the stairs?
Thank you!
Beschriftungen (1)
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: adri3362
A ceiling plan is looking up so View depth should be above or at least equal to the top of the view range
Nachricht 3 von 4
rmc9WR3X
als Antwort auf: ToanDN
Or Autodesk could just speak English.
Nachricht 4 von 4
kayla_snow
Thank you!! I was thinking that had something to do with it
