View Depth Linked File Problem
fitrananda.24116120
fitrananda.24116120
I have two Revit models. the first for the building and the second for the site plan. in the site plan, there is a railing under the floor. in this site plan file, the gutter is not visible (Normal) (see the first picture) but when I enter the site plan model into the building model, the gutter line is visible (abnormal) (see the second picture) how can I manage this, to return to normal?
- Is the view in Wireframe mode?
- Does changing the view range bottom to 0 instead of -100 help?
- If all else fail, you can create a view in the site model exactly how you want it to look, then set the link instance in your building model view to By Linked View and choose that site view
fitrananda.24116120
Yeay so silly that I forgot not to change the view to Hidden Line. thank you ToanDN
can i ask something, when i upgrade model like building from revit 2019 to revit 2022, it’s look like the building was crack, for example the line, wall not function and cannot see, how to fix that.
