How can I get the callout to cut with my scope boxes and match lines? I have large callouts that go off of the page.
Wellcome the Answer Day:)
You can reduce the scale of the view.
Thank you for your post. You should be able to resize the scope box as well and adjust (per above) as needed. I have included a link below with details on this. I hope this helps.
Resize Scope Box: http://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU...
View Scale: http://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revit...
For additional Reference,
View Callouts Overview and settings: http://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU...
Dan, I think you're talking about a problem I've had as well.
Suresh and Michael, I believe Dan is talking about the Callout boundary line. When you use a Scope Box on a View with a Callout on it, the CAllout boundary extends past the edge of both the Crop Region and the Annotation Crop. (See attached image)
The Callout Boundary should respect the Annotation Crop.
I am also currently having issues with this. The boundary of my enlarged plan view (callout) does not crop with the scope box (even with an annotation crop). Has anyone found a solution yet?
No real solutions other than using two crop regions, one on each side of the match line, referencing the same enlarged plan.
