View boundaries too large
tom_mccarrick
tom_mccarrick
When exporting a sheet with several views to a dwg file, I get the message: "The view boundaries for the identified views are too large to export. Use a crop region to reduce the boundaries of the view." Is there a way to identify which view is causing this? I have checked each view, and the crop regions are all within the boundaries of the sheet.
nozci
Go to views one by one and hit Z and F on the keyboard and check if there is an unexpected element away from the main drawing.
tom_mccarrick
I did a Zoom Fit on each view, and I didn't see anything away from the main drawing.
tom_mccarrick
The Coordination Model was causing the problem. When I turned it off ,  I was able to do the dwg export.
