Video driver error for Revit 2017
7 ANTWORTEN 7
Nachricht 1 von 8
6272 Aufrufe, 7 Antworten
I installed revit 2017 on windows 10 64bit and I keep getting a video driver error must exit message before it crashes. I tried updating my graphics card and java as well as reinstalling revit and I keep getting the same error.
7 ANTWORTEN 7
Nachricht 2 von 8
RDAOU
als Antwort auf: Anonymous
@Anonymous
That depends on which Graphic Card  (Type/Brand/Mod/Speed)  you have installed... Try the following
In Revit OPTIONS: Under Graphics Tab >>>>> Uncheck the "Use Hardware Accelleration"
Nachricht 3 von 8
Maybe upgrading to 2017.2 will solve?
What card do you use?
Can you access Graphics under Options before crashing to see Video Card Driver Status?
Nachricht 4 von 8
tugasdotdadakan
als Antwort auf: barthbradley
i've got same trouble here . i try to disable hardware acceleration but have same result . any another solution ?
Nachricht 5 von 8
THANKYOU SO MUCH!!!
Nachricht 6 von 8
als Antwort auf: RDAOU
It works, thanks Mate!
Nachricht 7 von 8
 Unchecking the "Use Hardware Accelleration" works great! Thank you!! :leicht_lächelndes_Gesicht:
Nachricht 8 von 8
I had the same question. Also asked in the forum. No one responded and then I continued to search. I met your answer. Then I remembered that this also happened at Autocad 2019. He therefore does not recognize the video card and therefore gives an error message. Thank you so much, that I could still find it.
Greeting,
John
