Video Card Issues withRevit 2016 using 2016 MacBook Pro
6 ANTWORTEN 6
Nachricht 1 von 7
693 Aufrufe, 6 Antworten
I have a new 2016 MacBook Pro and am using BootCamp (Windows 10 Pro) to use Revit 2016.  The MacBook Pro has an AMD Radeon Pro 460 graphics Card. When I bring  up Revit, all the graphics (icons) are not displaying and I get flickering in certain parts of the UI (screen) and sometimes slow performance.
When, I go into Revit's Options/Display settings, I get the following message:  "The installed video card 'AMD Radeon Pro 460' has not been tested with Revit. You may continue to use Hardware Acceleration. If you experience graphics display issues, you should: - Turn off Hardware Acceleration."  I've turned off the Hardware Acceleration and have tweaked the System Display resolution and text/app % back and forth but, still the same issue.
Does Revit 2016 Support AMD Radeon graphics card and if so which drivers or versions?  Thanks!
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
What resolution and display scaling did you set it to?
Nachricht 3 von 7
FGPerraudin
hi @Anonymous,
Your question is difficult, as the issue might come from your Video Card, or from the emulation of a windows OS...
Safest would be just to deactivate 3D acceleration (Revit > Options > Graphics > untick "use Hardware acceleration")
François
Francois-Gabriel Perraudin
BIM management and coaching
Nachricht 4 von 7
als Antwort auf: FGPerraudin
Hi I did deactivate  the Hardware acceleration and change the app/text from 200% to 150%.  As well, I've changed the screen resolution down as well from the default for the MacBook Pro 15in.  Still the same problem.
Nachricht 5 von 7
als Antwort auf: ToanDN
I changed to scaling down to 150% from the default of 200%.  I can't recall the resolution and I'm on my work laptop now but, will check and put here later.
Nachricht 6 von 7
judith
I had to turn off the retina display and change the scale on my current Macbookpro to stop the graphics from blinking. It worked. I am thinking at getting the new MacbookPro but want to know if the Radeon card will be a problem. Sounds like I need more info. Let me know if that works.
JP
Nachricht 7 von 7
als Antwort auf: judith
Thank you. I will definitely let you know if it works.
