Very slow speed Revit 2017
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
javier.zavala
275 Aufrufe, 2 Antworten
I know checking for errors help. but is there any other tips or solutions i can try. I mostly work with autocad so i'm kind of a new to revit .
if anyone have any ideas or settings i can change for revit that will be great. i know for autocad i turn off acceleration and RUN PURGE AND AUDIT and sometimes the overkill command does revit have something similar?
2 ANTWORTEN 2
Nachricht 2 von 3
DarrenP
als Antwort auf: javier.zavala
don't know what you mean by slow but this gives a few tips on improving Revit Performance
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
DarrenP
Nachricht 3 von 3
Viveka_CD
als Antwort auf: DarrenP
Hi @javier.zavala
Here is an article which touches on a lot of reasons for slow performance in Revit. There are some steps to try such as disabling add-ins that you can try.
For graphics cards, please reference the certified list for cards that have been tested with Revit.
Can you share a journal file to investigate further on what may be causing this slowdown? Let me know if you have any questions, thanks!
