Very complex roof opening
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
NP---MD
268 Aufrufe, 3 Antworten
I'm trying to cut a dormer opening in this roof - see below:
The opening would need to cut the roof on two planes as the dormer itself sit over the roof valley. I get a whole load of errors when trying to perform the cut with the dormer cut tool.
As always, I could fall back on some sort of void cut family.
But, before I do, I wanted to see if anyone had any advice or knew any other ways of achieving the cut effectively and efficiently.
3 ANTWORTEN 3
Nachricht 2 von 4
Karol_Piroska
als Antwort auf: NP---MD
why do you have all roofs as separate elements instead of one outline with different slopes as required?
I quickly joined the two roofs into one and cut the ope using the dormer tool . Alternatively you can use shaft opening or vertical opening through the roof(s)
Nachricht 3 von 4
Nachricht 4 von 4
NP---MD
Yes - still at it!
Thanks KarolPiroska that's done the trick!
