Hey all,
I'm trying to build a curtain wall that curves over the top of an archway (see section), but am stumped as to how the best way to do it would be - I've tried building an in-place mass, and then using the pick face tool to build the curtain wall to match the curved face of the mass, but I keep getting an error that I can only use that tool with generic walls, rather than curtain walls. is there a different way to do this, or what else would be the best option to construct a curtain wall archway such as this, where the curtain wall starts to curve up and over at the top?
Cheers,
Gelöst! Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
You can try using Roof by Extrusion > sloped glazing for the arch portion and curtain wall for the side walls. You'll still be limited to system panels for the arch though. You'd need to consider going the adaptive panel family/massing/divided surface route for more complicated conditions.
Steve Stafford
