I'm trying to do a wall sweep around the corner of those two walls shown below, but Revit is not allowing me! The first sweep on the left is right at the edge of the wall. I'm trying to add another sweep at the other side, so I can continue on the next wall across uniformly. Thank you.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Thank you. That solved the problem. However, it created another one! The top of the sweep is not trimmed as the wall side it is on. How can I fix that?
Maybe grip stretch the wall sweep to cover the gap then join geometry with the roof.
