Question on vertical surfaces for floor systems:
How do I cover a floor system A) on the exterior with stucco (1st screenshot and section) and on the interior with drywall? As you can see in the screenshots below, the exterior stucco surface should extend to the bottom of the floor system. On the interior, the floor system should be covered with gyp board.
Thx for your help.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
- Push the edge of the floor to align with the back side of the exterior wall finish
- Match the wall base offset with the underside of the floor
- Join them
Toan - you're awesome - thx for all your help if I have not said so yet.
