Vertical Roof Cut Failure
4 ANTWORTEN 4
Nachricht 1 von 5
BigPicture045
293 Aufrufe, 4 Antworten
4 ANTWORTEN 4
Nachricht 2 von 5
syman2000
als Antwort auf: BigPicture045
Yes vertical roof cut will have issues especially if Revit find there are multiple slope. You may want to use in-place family. Choose roof as category and create a box. Then change the property from solid to void. Use cut tool to cut the roof with the void.
Nachricht 3 von 5
elzohry2007
yes
i have some issue
so
i use model in place instead
Nachricht 4 von 5
BigPicture045
als Antwort auf: syman2000
Okay, it seems it would be easier to create two separate roofs.
Nachricht 5 von 5
Sort of a Gambrel.  Another method you could use would be Roof BY Extrusion. This way you could make the two roofs into one monolithic construct.
