Vertical opening within roof-based family
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
g_thong
564 Aufrufe, 9 Antworten
I'm trying to create a vertical opening that is hosted in a rooflight, so that if I place the window in a sloped roof, the opening will still be vertical in the project. Is this possible? I'm working in Revit 2023
Thanks!
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: g_thong
Are you talking about skylight shaft walls? If so, use Project Walls.
Nachricht 3 von 10
g_thong
als Antwort auf: barthbradley
Sorry, what do you mean by project walls?
Nachricht 4 von 10
Please confirm. Are you talking about the skylight shaft?
Nachricht 5 von 10
g_thong
Yes I am. Our roof buildup is quite thick so it is very obvious that the opening is not vertical, but is instead perpendicular to the rooflight.
Nachricht 6 von 10
Are you using the Attach Top/Base Tool to attach vertical walls to the roof?
...wait a minute. are you talking about the opening?  Remove the opening cut from the Window Family and use a Shaft to cut the opening in the Project.  Or use an In-Place Void Extrusion.
Nachricht 7 von 10
syman2000
It is possible, you have to built a family with angle.
Nachricht 8 von 10
g_thong
Thank you, I was hoping I'd be able to have the opening hosted in the family so it would update with the size of the rooflight, but this is also a solution
Nachricht 9 von 10
g_thong
als Antwort auf: syman2000
Thank you for this! Do you know if there is any way to have the roof of the slope reported as a reporting parameter, or is this not possible?
Nachricht 10 von 10
syman2000
Currently it isn't possible.
