Ventilation in magicad revit f*cks up, help needed
5 ANTWORTEN 5
Nachricht 1 von 6
eliz0305
635 Aufrufe, 5 Antworten
So I've made ducts on my 1st floor but whenever I do the exact same thing on the remaining floors (2-4th floor) the ducts are just plain lines instead of looking like actual ducts. How do I change this? It's not like I touched anything in settings.
 (Left is my 1st floor where ducts are looking normal, right is how it looks in plan view in the remaining floors)
5 ANTWORTEN 5
Nachricht 2 von 6
RobDraw
als Antwort auf: eliz0305
The view graphics settings need to be the same for each view. Use the "correct" view to create a view template and you can then assign the view template to the other views.
A slightly quicker fix might be to change the detail in the views showing the duct as single line. It's probably on coarse.
Rob
Nachricht 3 von 6
Set the view from Coarse to Medium or Fine.
Nachricht 4 von 6
RobDraw
You're going to need to change the subject to something more appropriate.
Rob
Nachricht 5 von 6
View Detail Level = Medium or Fine - not Coarse.  That will unf*ck it.
Nachricht 6 von 6
Have you considered contacting Magicad?  They claim to be "100% Compatible" with Revit, but the caveat is " when a suitable object is found."  Maybe it's Magicad - not Revit - that "f*cks up".
FWIW.
