I've been stuck for hours figuring out why my plans still have a white background. Checked all possible visibility graphics options but no luck. Very weird as I was I able to export my plans a while back with no problems. Hope someone can help me.
Gelöst! Gehe zur Lösung
Gelöst von franzeairon.saavedra.archi. Gehe zur Lösung
You need to supply more info. Like a PDF / screenshot showing what you want and what you get.
Thank you so much for your response. Posted this out of desperation and didn't expect to get replies. Attaching here what I achieved before and what I'm getting now. I use adobe programs for presentation quality and I was hoping to directly import the exported pdfs without having to photoshop them to retain the vector quality but unfortunately it's acting up. Hope this helps understand my situation, thanks!Fully vectorized
With white Background
Hello
Make sure that the shadow, color, etc. are not active in the view when outputting.
Yes all are turned off, no overrides in the visibility graphics and room color fills are unchecked. Are there other places which I should check/uncheck? This is very frustrating as I'm exporting with the exact same setting I used before. Thank you for your reply
I tested
When you output, the background is transparent.
Yes it normally should, I don't know why for me it keeps getting a white background (see the attached photos above).
Was able to solve this. The difference between my current and previous plan is the filled region I placed on the restrooms. I don't know if its supposed to work that way but when I deleted it, I was able to export a fully vectorized pdf.
