Hi
Due to the huge mass of tasks and constraints of time our engineering group has decided to cooperate on modeling of the same project in Revit. Each one has attended to do a portion , as you know immense variety of possible ways for structural and architectural modeling in revit which could have been consumed , has become an issue for us , so we are looking for a reference modeling direction in order to be fallowed by every single employee .We are kindly asking for legislation or a template to upsurge reliability and discipline of our project. appreciate you in advance for any solution or templates you might have and send for us.
thanks.
Members of this forum aren't going to solve this problem for you by sharing a template or even advice. You and your coworkers are going to have to decide what works best for you all and the clients you serve.
If you don't all have similar experience with Revit then that's one direction to pursue, get additional training and mentoring for those with less experience. Either hire a firm to help with that or dedicate the most knowledgeable staff to that task.
As for modelling techniques and habits. While there are a number of ways to produce a given aspect of a model, start with the ones that the software itself provides via the front door, the ribbon and its collection of commands. It shouldn't be a source of confusion as to which tool to use for, say placing columns. If it is then that is also a training/mentoring/standards discussion.
For ongoing advice, create posts here dedicated to a single complaint or concern and it will be more likely to get more responses.
Steve Stafford
my impression is that the information you need belongs mostly to the process ( BIM) then to instrument (Revit). That's a lot of information about BIM .
So, my recommend will be to have a look on some of BIM Standards.
Now, it depends which Standard applies to you area or to your project....
Some examples of such documentations (only UK and USA) :
Constantin Stroescu
