variable wall thickness?
4 ANTWORTEN 4
Nachricht 1 von 5
emorgan
1591 Aufrufe, 4 Antworten
Is it possible to have an instance parameter for a wall type width?  For example, if I have an air layer within a chase wall can I make the air layer variable rather than having to make a new wall type for each width?  Thinking similar to what you can do with a Revit roof...
Tags (3)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: emorgan
Not as an Instance Parameter.
...have you thought about just creating two walls with a separation between them?
....FWIW: we tried building void spaces into Wall Types before, such as soffits.  It ended up being a nightmare.
Nachricht 3 von 5
2nd using two walls for chases vs one...they cleanup better in plan too.
Nachricht 4 von 5
emorgan
als Antwort auf: barthbradley
yeah, our office just has a "certain way of doing things" and that means making a plumbing wall into a single wall type.  i'll fudge it if i have to, just curious if there was a way to do it.  thanks!
Nachricht 5 von 5
Depends on how you present the walls on plan, if you use Coarse like any normal person does, then you don't have to create a new wall type for each thickness.   For example, with one wall type of 100 mm you can have several configurations:
- a single 100 mm wall
- a 200 mm wall from 2 adjacent 100 mm walls joined
- a 250 mm wall from 2 adjacent 100 mm walls and another 100 mm wall offset 50 mm joined
and so on.
