Variable Dimensions Revit
1 ANTWORT 1
Nachricht 1 von 2
rogerio.souzaP6GWE
190 Aufrufe, 1 Antwort
I have this project that have several similar elements, with the same name (Ex. V101) but with different dimensions. The draft team extracted only one drawing for all similar elements and inserted the maximum dimension. But the costumer didn´t approve this. So we have to updated all documents inserting a table for the exact dimension of each variation of this element.
Is there a way to do this automatically? Otherwise this update will consume the time of our lives (lol).
Thanks in advance.
1 ANTWORT 1
Nachricht 2 von 2
A schedule assigned to the category of the family should be able to report each instance and the dimensions used if the parameters are either using built-in dimension parameters or shared parameters. Include the Mark parameter so each instance in the project can be identified individually in views by tagging the Mark parameter. This way they can compare a plan against a schedule of the families.
Steve Stafford
