Variable Components
Variable Components
Variable Components
Hi there
Does anyone perhaps know how I can create components, eg. windows so that once they've been placed, in 3D view I am able to drag with the use of snapping points on the window to reach the desired window size/dimensions.
I know this is possible as I found Revit tutorials. However this specific problem is not discussed in the video. The file has just been provided.
Help will be super appreciated. Thanks
Make height and width INSTANCE parameters and then size them in the Project using their Shape Grips.
ennujozlagam
Oops sorry wrong screencast.
HA, HA! I was wondering WTF, @ennujozlagamSmiley LOL  Nice Screencast though.
Here @Anonymous; this is what I was talking about above:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Revit-Customize/files/GUID-C30A7EFC-3030-4E9D-A305-C66B50E1DF75-htm.html
ennujozlagam
Sorry I don't have window but I have door screencast they have same process. thanks
<iframe width="640" height="680" src="https://screencast.autodesk.com/Embed/Timeline/204bb56d-6b1e-44ef-bcd0-56737e7d549c" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
ennujozlagam
@Anonymous Ha, Ha...☺ 😂
@Anonymous wrote:
Hi there
To be able to stretch a family using grips in 3D, you need to use Reference Lines with Instance Parameters to constrain the geometry in the family.  Using Reference Planes can only let you stretch the family using grips on 2D views.
