V notch into a beam
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
FSiedschlag
575 Aufrufe, 4 Antworten
V notch into a beam
Modelling a new canopy I need to achieve the following notching into a beam. See yellow are below.
I'm not having much success, as the cut geometry is working, but I'm getting the opposite of the desired shape.
What am I doing wrong?
Thanks.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: FSiedschlag
Like this?  Use Cope tool.
Nachricht 3 von 5
FSiedschlag
als Antwort auf: ToanDN
Hmm... my tool is called notch... but it's not really working.
Would you mind explaining how you got the first two beams to be notched at 45 degrees?
I used the cut geometry along with a reference plane, and that might be the problem my notching is not working.
Nachricht 4 von 5
Nachricht 5 von 5
FSiedschlag
Perfect.
Thanks.
