Hi, Iam looking for some help. We have a building that is on a steep slope, level difference from one end of the building to the other is over 6m. We are using Plan Regions on our plans so that all the different ground, first & second floor level show correctly rather than one end of the building been at ground floor and other at second floor.
On a different sheet we are applying Override filters to the walls. When the V/G is set to course details the filters hatch work correctly to the whole plan. We would like the detail level to be fine, but when we change the detail level to either medium or fine some wall no Loger have the filter applied. I know it's something to do with the plan regions because if we delete the region the filter hatch is applied correctly. Does anybody know what is coursing the issue and how to fix it?
My guess would be that there is another override acting on those walls - an override higher up in hierarchy and therefore taking precedence.
