Using two different Section heads in same views
7 ANTWORTEN 7
Nachricht 1 von 8
dan.luxford
1560 Aufrufe, 7 Antworten
Hi all, I am new here, so please bear with me. I work in building services detailing HVAC for manufacture and installation.
As you can see from the title, I have created two different Section heads.
First one is used for main sections showing sections across duct runs.
Second one is used for what we call scrap sections (just showing a few items for manufacturing purposes only).
I have loaded the two families, and duplicated the types. The problem I  have is when I edit the second family
(Scrap Section) to the correct head the first head also changes to the (Scrap Section) head.
Am I doing this correctly?
Is there a way to do this?
Thanks for looking
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: dan.luxford
Video is unavailable, but it sounds like you didn't duplicate and modify the Section Tag. Drill down further.
Nachricht 3 von 8
dan.luxford
als Antwort auf: barthbradley
Hi Barth Bradley, thank you for replying.
I think I must be missing something from your reply.
I cannot duplicate from "System Family: Section Tag".
I do however have three types of Section heads (in the Type dropdown list). all made via the duplicate button.
I also do not know why you cannot view the video.
I'm having a bad day......
Link to video: https://www.youtube.com/watch?v=N4WT9ctaqtw
Nachricht 4 von 8
You can also access/duplicate/modify named Section Tags under Additional Settings on the Manage Tab.
Nachricht 5 von 8
dan.luxford
I'm just doing that procedure via "change the Section head" help on Autodesk Knowledge Network....
Without any success so far. I'll keep you posted.
Nachricht 6 von 8
I'm pretty sure what you are doing is just changing the Head of the Section Tag Type, instead of assigning a different Section Tag to each Section.  In other words, both Sections are using the exact same Section Tag Type.
Nachricht 7 von 8
dan.luxford
Thanks for replying, I have followed the instructions to the letter (See image).
I still cannot get it to work, I'm giving up for the night, thank you for all your effort in helping me.
Nachricht 8 von 8
