Using sweep to module a furniture
How can you use sweep to make a panel that is curved all around its edges?
The panel is mounted on a wall, and I need all its corners to be curved, but cant manage to do a sweep for it all. Im attaching an elevation of the panel I need.
Any help is appreciated!!
The image attached is blank so it is pretty easy to achieve 😉
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community! Smiley Happy
Are you looking to model an organic furniture piece as your title proposes? or a panel with curved edges. An image will help us understand your requirement better.
You can use a sweep or a void sweep to achieve these results.
The following link HERE is a general method for creating a sweep. Steps may vary depending on your design intent.
Looking forward to your reply update.
Sahay_R
It sounds as though you need to create a sweep with a curved profile.
Create>>Sweep
Start with a generic model template. Sketch the required path. Sketch the profile. Accept.
Now, if I could see what it is that you need to achieve, then I can be more specific.....
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
