Using Schedules
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
417 Aufrufe, 8 Antworten
Using Schedules
I am working on a permit set for a building.  We have several different legends and schedules in this project.  My issue is that I need to use the building schedule on several different pages however as I try to drag and drop the schedule and move it into position on a specific sheet, it moves that same schedule on the other sheets.  How do I correct this problem.
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: Anonymous
That's strange.  Moving a schedule on one sheet should not move other instances of it on other sheets.  Only if you physically change column width or break point.
Nachricht 3 von 9
chrisplyler
That is very strange behavior you are describing.
I'm a bit confused. What schedule are you calling the "building schedule?"
Nachricht 4 von 9
als Antwort auf: chrisplyler
It's the building schedule that lists sq footage, it's seems that my issue
only happens when you change the columns size or break the table up, if I
don't modify the table, I don't have an issue but if I modify the table
then it changes on every sheet
Nachricht 5 von 9
Nachricht 6 von 9
Yes if you change columns size or break point then it will reflect on all instances (see my screencast above).  If you need to do that, duplicate the schedule and place the copy on the other sheet.
Nachricht 7 von 9
chrisplyler
Well of course. Changes to the display/format of a schedule will show up everywhere that schedule is. But the on-sheet POSITION shouldn't change from one sheet to another.
If you need the same schedule data with differing display/format characteristics...duplicate the schedule and make changes to the display/format of that one and use it. Now you've got two of the same schedules but they look different. You can put one them each where you want them.
Nachricht 8 von 9
Fasho...preciate your help
Nachricht 9 von 9
Viveka_CD
Hi @Anonymous
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. - Thank you.
