Using schedule calculated total in a formula
13 ANTWORTEN 13
GELÖST
Nachricht 1 von 14
Keith_Wilkinson
11737 Aufrufe, 13 Antworten
Is it possible to use a schedule calculated total in another formula?
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
13 ANTWORTEN 13
Nachricht 2 von 14
L.Maas
als Antwort auf: Keith_Wilkinson
No, the formulas are row based.
The only possible solution would be to add a parameter to the families. In this parameter you would have to enter the calculated total manually (or automatically through the API). When automating you would risk to create circular references.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 14
Keith_Wilkinson
als Antwort auf: L.Maas
I thought that might be the case.  Pity.
Might try doing something with Dynamo instead... ;o)
Maimonides
Nachricht 4 von 14
L.Maas
Dynamo should be a possibility. I understood it should be possible to pull totals from a schedule.
Louis
Nachricht 5 von 14
Keith_Wilkinson
My thinking was that I could actually produce the total in dynamo.
Mind you I'm saying that with no real idea of what I'm doing or how I'm going to do it.  But I like the idea of at least trying something in Dynamo!  :leicht_lächelndes_Gesicht:
Maimonides
Nachricht 6 von 14
Not to revise an old thread... but, you can extract the calculated total as a percentage and place it in a calculated field on the same row.  To do this; set the field you want the total from to show "calculated totals" under formatting.  Then create a new field to extract the percentage of the total of the field you need the total value from; Make sure you go back to the formatting tab and change the field formatting from percentage to general.  Once that is set up, just create a new field to calculate the total by simply diving the first field by the percentage, it should then give you the total in the field for the row.
Nachricht 7 von 14
als Antwort auf: Anonymous
Brilliant!!
I tested it and it works without even changing the Percentage format to General.
Nachricht 8 von 14
I know this is an old post, but sometimes gets actual :Gesicht_mit_Zunge:
Is it possible to push these "calculated values" in a family tag? I manage to create schedule, I can't find the way to push them in the tag....
Thanks!
Nachricht 9 von 14
Only if the original parameter you were getting the calculated total from is a shared parameter.
Nachricht 10 von 14
Thanks so much for this.. I've been going nuts trying to play with the formula to extract avergae unit area per level!
I found the other posts quite confusing - yours was the simplest to follow!
Cheers,
Nidhi
Nachricht 11 von 14
marko.Zeljkovic
absolutely brilliant. thank you so much.
Hint for posting formulas, rename the parameters to 2 - characters long so its easier to follow. Cheers
Nachricht 12 von 14
RDAOU
Nachricht 13 von 14
Keith_Wilkinson
als Antwort auf: RDAOU
it's the forum - on any post that I've started, if someone replies, it automatically likes it for me and sets it as the solution - despite multiple requests Autodesk hasn't managed to fix it.  Can't say I'm surprised...
Maimonides
Nachricht 14 von 14
artM23CU
Or Autodesk could actually create a not so convoluted way of doing things that it takes forums and 300 hours to create automated schedules based on data already available. This has been a massively annoying exercise which could have been avoided with some simple tools in revit. We pay 3500per year per station and the changes from version to version are inconsequential. There's still no built in way of renumbering items sequentially, and it's been what 20 years now? By the time autodesk fixes this AI will negate the need for revit altogether.
