using real dimensions
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
263 Aufrufe, 2 Antworten
hi
just wondering how to create a floor plan from measurements i already have which are fairly specific.
can i just somehow type in the dimensions i have and create a floor plan for those specific measurements somehow??
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
You can use measurements....but you have to keep aware of where your wall justification lines are.
I prefer to draw in all my walls as close to the other plan as possible, then use the temporary dimensions to move the walls to where I want them per the measurements.
Nachricht 3 von 3
chrisplyler
Agree with mpwuzhere.
Just draw walls that are roughly, approximately in the right place required to achieve your plan layout. Dimensions the walls from each other as appropriate. Then select a wall and type the desired value into the appropriate dimension string.
